Introducción
This guide will show you how to remove the screen of the Motorola Moto G5 Plus so that you can access the internal components for replacement.
Qué necesitas
Stick the small suction cup onto the screen. Use this to remove the screen from the phone frame in later steps.
Using a heat gun on a low setting, slowly raise the temperature of the screen by repeatedly running the heat gun along the edges of the screen. This will soften the glue that holds the screen to the phone frame.
Use the suction cup to gently pull up on the screen while using the plastic opening tool to gently pry the edges of the screen up.
Once the screen has been completely separated from the phone frame, flip it to one side to expose the inside of the phone.
