Introducción
This guide will help with the replacement of a broken or faulty motherboard.
Herramientas
Partes
No se especificaron partes.
Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
Pry with your fingernail or twist the spudger to release the back cover from the phone.
Insert your fingernail or the flat end of the spudger into the notch below the battery.
Pry with your fingernail or spudger until you free the battery from its recess.
Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
9 personas más completaron esta guía.
Un Comentario
is a xt1670 logic board compatible with a xt1671 phone?
