Saltar al contenido principal
Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement
Qué necesitas
  1. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Battery: paso 1, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 3, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 3, imagen 2 de 2
    • Use the opening pick along the edges to separate the camera lens glass from the board.
  4. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 4, imagen 1 de 1
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 5, imagen 1 de 1
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 6, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 6, imagen 2 de 2
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 7, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 7, imagen 2 de 2
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 8, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 8, imagen 2 de 2
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Ringer Speaker: paso 9, imagen 1 de 1
    • Remove seven 4 mm screws with the T5 Torx screwdriver.
  10. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 10, imagen 1 de 2 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: paso 10, imagen 2 de 2
    • Remove the speaker using an ESD-safe spudger.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 63
