Saltar al contenido principal
Motorola Moto G Power (2020) Fingerprint Sensor Replacement
  1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 2, imagen 1 de 1
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 3, imagen 1 de 1
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Fingerprint Sensor: paso 4, imagen 1 de 1
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 6, imagen 1 de 1
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: paso 7, imagen 1 de 1
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
Conclusión
Harry Jung
Miembro Desde 06/23/22
736 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 26
Todo El Tiempo: 647
