Introducción
This guide shows you how to replace the speaker on a Motorola Moto G 1st Generation smartphone.
Qué necesitas
Paso 1 Rear Panel
Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use a plastic opening tool to remove the protective cover.
Use the plastic opening tool to remove the Speaker from the protective cover.
2 personas más completaron esta guía.
