Saltar al contenido principal
Motorola Moto G 1st Generation Midframe Replacement
Qué necesitas
  1. Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: paso 1, imagen 1 de 3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: paso 1, imagen 2 de 3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Cover: paso 1, imagen 3 de 3
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Motorola Moto G 1st Generation Midframe Replacement: paso 2, imagen 1 de 1
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
    • In some version of this phone, a microSD memory card can be installed. If so, you must also remove these cards.
    • Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
    • If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
  3. Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: paso 3, imagen 1 de 3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: paso 3, imagen 2 de 3 Motorola Moto G 1st Generation Midframe Replacement, Removing the Back Plate: paso 3, imagen 3 de 3
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: paso 4, imagen 1 de 3 Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: paso 4, imagen 2 de 3 Motorola Moto G 1st Generation Midframe Replacement, The Inside of your Phone: paso 4, imagen 3 de 3
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
Conclusión
9 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-6, Brown Fall 2014 Miembro de USF Tampa, Team 1-6, Brown Fall 2014
USFT-BROWN-F14S1G6
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 3,741
