Saltar al contenido principal
Motorola Moto G 1st Generation Battery Replacement
Qué necesitas
  1. Motorola Moto G 1st Generation Battery Replacement, Rear Panel: paso 1, imagen 1 de 3 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: paso 1, imagen 2 de 3 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
    • Remove any installed SIM card and memory microSD cards.
    • Push the SIM card into the phone, and the spring eject mechanism should release the card.
    • The microSD memory card(s) may not have an eject mechanism. If so, they must be removed carefully by pushing on the raised edge/bump that is built onto the card. Use your fingernail or a plastic or rubber tool, but not one that will scratch and damage the delicate card.
    • Patience must be taken to prevent irreversible damage and loss of data on the card.
  2. Motorola Moto G 1st Generation Battery Replacement, Removing the Screws: paso 2, imagen 1 de 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Battery Replacement, Battery Cover: paso 3, imagen 1 de 2 Motorola Moto G 1st Generation Battery Replacement, Battery Cover: paso 3, imagen 2 de 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: paso 4, imagen 1 de 2 Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: paso 4, imagen 2 de 2
    • Disconnect the connection between the Battery and the Mother Board by using the Pry tool.
  5. Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: paso 5, imagen 1 de 2 Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: paso 5, imagen 2 de 2
    • With the battery already disconnected,work around its edge with the pry tool to remove it from the assembly.
    • The battery is attached with a sticker, so it may take some work to pry up. Just work at it slowly and carefully until you get it.
Conclusión
3 personas más completaron esta guía.
Radostin Lobodov
Miembro Desde 10/16/14
2,904 Reputación
6 Guías creadas
Equipo
Un comentario
Hello!
I have just completed this operation. I would like you to know that my Moto G 1st Generation needed a T4 Torx screwdriver.
Other than that, everything went fine!
Best Wishes,
Bubba G
Bubba G - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 4,090
