Saltar al contenido principal
Motorola Moto E6 Speaker Replacement
Qué necesitas
  1. Motorola Moto E6 Speaker Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto E6 Speaker Replacement, Back Cover: paso 1, imagen 2 de 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: paso 2, imagen 1 de 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: paso 5, imagen 1 de 3 Motorola Moto E6 Speaker Replacement: paso 5, imagen 2 de 3 Motorola Moto E6 Speaker Replacement: paso 5, imagen 3 de 3
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,138
