Saltar al contenido principal
Motorola Moto E6 Motherboard Replacement
Qué necesitas
  1. Motorola Moto E6 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto E6 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Motherboard Replacement, Battery: paso 2, imagen 1 de 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
Conclusión
Una persona más ha completado esta guía.
Matthew Zelten
Miembro Desde 01/23/20
471 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S2-G3, White Winter 2020 Miembro de Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,338
