Introducción
This guide shows how to replace the front facing camera in a Motorola Moto E6. It may need to be replaced if the front camera is failing to capture photos and/or project an image on the screen.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Qué necesitas
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
Remove the press fit cable holding the camera on the back of the motherboard using the plastic opening tool.
