Saltar al contenido principal
Motorola Moto E6 Charging Dock Replacement
Qué necesitas
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: paso 1, imagen 2 de 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: paso 2, imagen 1 de 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: paso 3, imagen 1 de 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: paso 4, imagen 1 de 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: paso 5, imagen 1 de 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: paso 6, imagen 1 de 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Conclusión
6 personas más completaron esta guía.
Matthew Zelten
Miembro Desde 01/23/20
471 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S2-G3, White Winter 2020 Miembro de Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 2,893
