Saltar al contenido principal
Motorola Moto E4 Motherboard Cover Replacement
Qué necesitas
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: paso 1, imagen 1 de 2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: paso 1, imagen 2 de 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: paso 2, imagen 1 de 2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: paso 2, imagen 2 de 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: paso 3, imagen 1 de 2 Motorola Moto E4 Motherboard Cover Replacement: paso 3, imagen 2 de 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Conclusión
2 personas más completaron esta guía.
Nate Tjepkema
Miembro Desde 01/24/19
1,236 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S2-G4, White Winter 2019 Miembro de Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 610
