Saltar al contenido principal
Motorola Moto E Motherboard Replacement
Qué necesitas
  1. Motorola Moto E Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Motherboard Replacement: paso 2, imagen 1 de 1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Motherboard Replacement: paso 3, imagen 1 de 1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Motherboard Replacement: paso 4, imagen 1 de 1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Motherboard Replacement: paso 5, imagen 1 de 1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Motherboard Replacement: paso 6, imagen 1 de 1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Motherboard Replacement: paso 8, imagen 1 de 2 Motorola Moto E Motherboard Replacement: paso 8, imagen 2 de 2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Motherboard Replacement: paso 9, imagen 1 de 1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
Conclusión
29 personas más completaron esta guía.
Alex Craig
Miembro Desde 03/11/15
2,611 Reputación
5 Guías creadas
Equipo
Colorado Springs, Team 5-7, Panko Spring 2015 Miembro de Colorado Springs, Team 5-7, Panko Spring 2015
UCCS-PANKO-S15S5G7
Miembros de 2
10 Guías creadas
7Guía Comentarios
In step 8, after pulling the black cable out, how do you insert it in the new motherboard again? I doesn't go in. There's a plastic clamp inside that too. How does one remove the outer metal box?
Ritwik Joshi - Contestar
Where should I find a new logic board? Motorola Moto E XT1022
Abhijith Palur - Contestar
Hi my moto e board not showing signal
Mehraj Udin Dar - Contestar
Where to get the new motherboard from?
HIM SHIKHAR BISWAS - Contestar
Hello All,
I wanted to repair my moto e too. >At first I thought the problem is the battery as the phone was not charging and so I removed the case and connected the phone without the battery to the chrager expecting it to boot up. But this does not seem to be the problem as there is no change in the status of the phone. How do I isolate the problem as a first step.
Thanks,
Psp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 18
Ultimos 30 días: 32
Todo El Tiempo: 23,480
