Saltar al contenido principal
Motorola Moto E 2nd Generation Display Assembly Replacement
Qué necesitas
  1. Motorola Moto E 2nd Generation Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Display Assembly Replacement: paso 2, imagen 1 de 3 Motorola Moto E 2nd Generation Display Assembly Replacement: paso 2, imagen 2 de 3 Motorola Moto E 2nd Generation Display Assembly Replacement: paso 2, imagen 3 de 3
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
  3. Motorola Moto E 2nd Generation Display Assembly Replacement: paso 3, imagen 1 de 3 Motorola Moto E 2nd Generation Display Assembly Replacement: paso 3, imagen 2 de 3 Motorola Moto E 2nd Generation Display Assembly Replacement: paso 3, imagen 3 de 3
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
Conclusión
37 personas más completaron esta guía.
Andre Romualdo
Miembro Desde 02/08/16
3,765 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 12-3, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-3, Eyestone Spring 2016
USFT-EYESTONE-S16S12G3
3 Miembros
14 Guías creadas
5 comentarios
Will the glue work againg when reassambling?
Rodolfo Coss - Contestar
Rodolfo, no - the glue cannot be reused during reassembly. There should be a step 4.
Step 4: enclosed you will find a rectangle of double-sided adhesive. Use scissors/knife to trim off thin strips of adhesive, and place these around the edge of the housing where the glue was previously bonded (remove any residual glue from the housing before placing the adhesive).
You can get the gist of it by watching from 9:52 on this youtube video on replacing a Moto G screen (different phone, same principle): https://www.youtube.com/watch?v=zdRJsQUl...
Now reverse the first 3 steps.
Mark Eldridge - Contestar
what if the black strip behind display get torn off while lifting the screen?
kalpitmairh - Contestar
Hi Andre, when you say “enclosed “ (in response to Rodolfo’s question, enclosed where?
Newby - Contestar
Just a heads up:
If you replace the screen, make sure to transfer the plastic ear piece from the original screen to the replacement. (It’s the one with the metal bar) I was unable to find a replacement through any of the suppliers I use.
J.K - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 46
Todo El Tiempo: 15,187
