Saltar al contenido principal
Motorola Moto 360 Rear Cover Replacement
Qué necesitas
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: paso 3, imagen 1 de 2 Motorola Moto 360 Rear Cover Replacement: paso 3, imagen 2 de 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: paso 4, imagen 1 de 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
Conclusión
9 personas más completaron esta guía.
Cole Twitchell
Miembro Desde 01/30/15
1,688 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-32, Amido Winter 2015 Miembro de Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Miembros
18 Guías creadas
Un comentario
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 12,871
