Saltar al contenido principal
Motorola Moto 360 O-Ring Replacement
Qué necesitas
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 O-Ring Replacement: paso 3, imagen 1 de 2 Motorola Moto 360 O-Ring Replacement: paso 3, imagen 2 de 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: paso 4, imagen 1 de 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: paso 5, imagen 1 de 2 Motorola Moto 360 O-Ring Replacement, O-Ring: paso 5, imagen 2 de 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: paso 6, imagen 1 de 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
Conclusión
2 personas más completaron esta guía.
Jake Steinorth
Miembro Desde 01/30/15
149 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-32, Amido Winter 2015 Miembro de Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Miembros
18 Guías creadas
3 comentarios
Where can you get your hands on a replacement o'ring?!
James S - Contestar
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Contestar
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 2,726
