Saltar al contenido principal
Motorola Moto 360 2nd Gen Vibration Motor Replacement
Qué necesitas
  1. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the watch band: paso 1, imagen 1 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the watch band: paso 1, imagen 2 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the watch band: paso 1, imagen 3 de 3
    • Use your finger or the tip of a spudger to compress the pin securing the watch band.
    • With the pin compressed, remove the watch band.
  2. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the trim ring: paso 2, imagen 1 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the trim ring: paso 2, imagen 2 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the trim ring: paso 2, imagen 3 de 3
    • Insert an opening tool to into the small notch next to the microphone hole.
    • Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
    • If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
    • Remove the trim ring.
  3. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the button trim: paso 3, imagen 1 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the button trim: paso 3, imagen 2 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the button trim: paso 3, imagen 3 de 3
    • Use an opening tool to slowly pry the button trim ring straight up.
    • If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it.
  4. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the button: paso 4, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the button: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a small pin spanner to unscrew the button.
    • If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
    • There is blue thread locker on these threads, so light heat on the button may help to soften the thread locker.
    • Remove the button.
    • There is a small red o-ring that may fall off the button threads when the button is removed. Make sure not to lose the o-ring.
  5. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the inner assembly: paso 5, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the inner assembly: paso 5, imagen 2 de 2
    • While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
  6. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 6, imagen 1 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 6, imagen 2 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 6, imagen 3 de 3
    • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
    • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
  7. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Open the inner assembly: paso 7, imagen 1 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Open the inner assembly: paso 7, imagen 2 de 3 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Open the inner assembly: paso 7, imagen 3 de 3
    • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
    • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
  8. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 8, imagen 1 de 1
    • Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
  9. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 9, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 9, imagen 2 de 2
    • Use a spudger to lift the locking flap on the display ZIF connector.
  10. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 10, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 10, imagen 2 de 2
    • Lift the display cable straight out of its connector on the motherboard.
  11. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the battery: paso 11, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement, Remove the battery: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to gently pry the battery out of the case.
    • The adhesive can be stubborn. If the battery does not come out initially, apply heat to soften the adhesive.
    • If the shield over the motherboard comes off with the battery, use an opening pick to separate the battery and the shield, then snap the shield back onto the motherboard.
    • Do not pull the battery all the way out after you separate it from the shield. There is a fragile battery cable that must be disconnected before the battery is completely removed.
  12. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 12, imagen 1 de 1
    Comprar
    • Use tweezers to lift out the grey plastic cover over the battery connector.
  13. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 13, imagen 1 de 2 Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 13, imagen 2 de 2
    • Use the point of a spudger to pry up the battery connector and disconnect the battery.
  14. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 14, imagen 1 de 1
    • Remove the battery.
  15. Motorola Moto 360 2nd Gen Vibration Motor Replacement, Vibration Motor: paso 15, imagen 1 de 1
    • After removing the battery the vibration motor will be visible.
  16. Motorola Moto 360 2nd Gen Vibration Motor Replacement: paso 16, imagen 1 de 1
    • Using a soldering iron, carefully remove the vibration motor by applying the tool under the vibration motor.
Conclusión
kushyal Budhan
Miembro Desde 10/02/17
640 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S6-G1, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G1, Remmell Fall 2017
USFT-REMMELL-F17S6G1
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 923
