Saltar al contenido principal
Motorola MOTO W755 Cell Phone Main Logic Board Replacement
Qué necesitas
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: paso 1, imagen 1 de 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: paso 1, imagen 2 de 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 2, imagen 1 de 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 2, imagen 2 de 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: paso 3, imagen 1 de 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 4, imagen 1 de 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 4, imagen 2 de 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 5, imagen 1 de 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 5, imagen 2 de 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 5, imagen 3 de 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 6, imagen 1 de 1
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 7, imagen 1 de 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: paso 7, imagen 2 de 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
Conclusión
C Miller
Miembro Desde 06/25/12
56 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-3, Regan SU 2012 Miembro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 1,512
