Saltar al contenido principal
Motorola MOTO W755 Cell Phone Key Pad Cover Replacement
Qué necesitas
  1. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement, Main Logic Board: paso 1, imagen 1 de 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  2. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 2, imagen 1 de 2 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  3. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 3, imagen 1 de 3 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 3, imagen 2 de 3 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 3, imagen 3 de 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  4. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 4, imagen 1 de 1
    • Remove the plastic covering completely from the body of the phone.
  5. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 5, imagen 1 de 2 Motorola MOTO W755 Cell Phone Key Pad Cover Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
  6. Motorola MOTO W755 Cell Phone Key Pad Cover Replacement, Key Pad Cover: paso 6, imagen 1 de 1
    • After removing the main logic board, use the plastic opening tool to poke from the back and peel off the key pad cover.
Conclusión
Roberta Glenn
Miembro Desde 07/11/12
43 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-3, Regan SU 2012 Miembro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 13
Todo El Tiempo: 1,210
