Saltar al contenido principal
Motorola MOTO W755 Cell Phone Camera Replacement
Qué necesitas
  1. Motorola MOTO W755 Cell Phone Camera Replacement, Battery: paso 1, imagen 1 de 2 Motorola MOTO W755 Cell Phone Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Camera Replacement: paso 2, imagen 1 de 2 Motorola MOTO W755 Cell Phone Camera Replacement: paso 2, imagen 2 de 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: paso 3, imagen 1 de 3 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: paso 3, imagen 2 de 3 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: paso 3, imagen 3 de 3
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  4. Motorola MOTO W755 Cell Phone Camera Replacement: paso 4, imagen 1 de 3 Motorola MOTO W755 Cell Phone Camera Replacement: paso 4, imagen 2 de 3 Motorola MOTO W755 Cell Phone Camera Replacement: paso 4, imagen 3 de 3
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  5. Motorola MOTO W755 Cell Phone Camera Replacement: paso 5, imagen 1 de 2 Motorola MOTO W755 Cell Phone Camera Replacement: paso 5, imagen 2 de 2
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  6. Motorola MOTO W755 Cell Phone Camera Replacement: paso 6, imagen 1 de 1
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  7. Motorola MOTO W755 Cell Phone Camera Replacement: paso 7, imagen 1 de 1
    • You now have the top panel completely detached.
  8. Motorola MOTO W755 Cell Phone Camera Replacement, Camera: paso 8, imagen 1 de 1
    • Using the plastic opening tool, peel back the plastic cover that is glued on top of the camera lens.
  9. Motorola MOTO W755 Cell Phone Camera Replacement: paso 9, imagen 1 de 2 Motorola MOTO W755 Cell Phone Camera Replacement: paso 9, imagen 2 de 2
    • Using the plastic opening tool, gently push the camera out from the front.
    • Part of the foam holding the camera will rip from the adhesive.
Conclusión
C Miller
Miembro Desde 06/25/12
56 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-3, Regan SU 2012 Miembro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,151
