Saltar al contenido principal
Motorola MC5590 LCD Screen Replacement
Qué necesitas
  1. Motorola MC5590 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Push in the battery release button.
  2. Motorola MC5590 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Pull out battery.
  3. Motorola MC5590 LCD Screen Replacement, Keyboard: paso 3, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement, Keyboard: paso 3, imagen 2 de 2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 LCD Screen Replacement: paso 4, imagen 1 de 3 Motorola MC5590 LCD Screen Replacement: paso 4, imagen 2 de 3 Motorola MC5590 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 LCD Screen Replacement: paso 6, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard cover.
  8. Motorola MC5590 LCD Screen Replacement: paso 8, imagen 1 de 3 Motorola MC5590 LCD Screen Replacement: paso 8, imagen 2 de 3 Motorola MC5590 LCD Screen Replacement: paso 8, imagen 3 de 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 LCD Screen Replacement: paso 9, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 LCD Screen Replacement, Speaker: paso 10, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement, Speaker: paso 10, imagen 2 de 2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 LCD Screen Replacement: paso 11, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 11, imagen 2 de 2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 LCD Screen Replacement: paso 12, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 12, imagen 2 de 2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 LCD Screen Replacement: paso 13, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 13, imagen 2 de 2
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 LCD Screen Replacement, LCD Screen: paso 14, imagen 1 de 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: paso 14, imagen 2 de 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: paso 14, imagen 3 de 3
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 LCD Screen Replacement: paso 15, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 15, imagen 2 de 2
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 LCD Screen Replacement: paso 16, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 16, imagen 2 de 2
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 LCD Screen Replacement: paso 17, imagen 1 de 2 Motorola MC5590 LCD Screen Replacement: paso 17, imagen 2 de 2
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
Conclusión
Tyler Jean
Miembro Desde 02/22/18
555 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 692
