Saltar al contenido principal
Motorola Lapdock 100 Phone Adapter Cable Replacement
Qué necesitas
  1. Motorola Lapdock 100 Phone Adapter Cable Replacement, Lower Case: paso 1, imagen 1 de 2 Motorola Lapdock 100 Phone Adapter Cable Replacement, Lower Case: paso 1, imagen 2 de 2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 2, imagen 1 de 1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 3, imagen 1 de 1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 4, imagen 1 de 2 Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 4, imagen 2 de 2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 5, imagen 1 de 2 Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 5, imagen 2 de 2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 6, imagen 1 de 3 Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 6, imagen 2 de 3 Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 6, imagen 3 de 3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 7, imagen 1 de 2 Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 7, imagen 2 de 2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Phone Adapter Cable Replacement, Battery: paso 8, imagen 1 de 2 Motorola Lapdock 100 Phone Adapter Cable Replacement, Battery: paso 8, imagen 2 de 2
    • Unplug battery from motherboard.
  9. Motorola Lapdock 100 Phone Adapter Cable Replacement: paso 9, imagen 1 de 1
    • Remove the battery.
  10. Motorola Lapdock 100 Phone Adapter Cable Replacement, Phone Adapter Cable: paso 10, imagen 1 de 3 Motorola Lapdock 100 Phone Adapter Cable Replacement, Phone Adapter Cable: paso 10, imagen 2 de 3 Motorola Lapdock 100 Phone Adapter Cable Replacement, Phone Adapter Cable: paso 10, imagen 3 de 3
    • Unplug the two connections to the motherboard to free the adapter cable.
    • You do not need to remove the motherboard to remove the phone adapter cable. We did this for picture purposes only.
Conclusión
Un comentario
Please advise which cables I need to be able to use my Motorola Lapdock SKU 65242 with other phones android/iPhone
Thanks
HgtConsort - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 764
