Saltar al contenido principal
Motorola E815 Front Screen Replacement
Qué necesitas
  1. Motorola E815 Front Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Front Screen Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Front Screen Replacement: paso 3, imagen 1 de 2 Motorola E815 Front Screen Replacement: paso 3, imagen 2 de 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Front Screen Replacement, Disassembling Motorola E815 Antenna: paso 4, imagen 1 de 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Front Screen Replacement: paso 5, imagen 1 de 2 Motorola E815 Front Screen Replacement: paso 5, imagen 2 de 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Front Screen Replacement, Front Screen: paso 6, imagen 1 de 3 Motorola E815 Front Screen Replacement, Front Screen: paso 6, imagen 2 de 3 Motorola E815 Front Screen Replacement, Front Screen: paso 6, imagen 3 de 3
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
  7. Motorola E815 Front Screen Replacement: paso 7, imagen 1 de 3 Motorola E815 Front Screen Replacement: paso 7, imagen 2 de 3 Motorola E815 Front Screen Replacement: paso 7, imagen 3 de 3
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
  8. Motorola E815 Front Screen Replacement: paso 8, imagen 1 de 2 Motorola E815 Front Screen Replacement: paso 8, imagen 2 de 2
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
  9. Motorola E815 Front Screen Replacement: paso 9, imagen 1 de 1
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
  10. Motorola E815 Front Screen Replacement: paso 10, imagen 1 de 3 Motorola E815 Front Screen Replacement: paso 10, imagen 2 de 3 Motorola E815 Front Screen Replacement: paso 10, imagen 3 de 3
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
  11. Motorola E815 Front Screen Replacement: paso 11, imagen 1 de 1
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
  12. Motorola E815 Front Screen Replacement: paso 12, imagen 1 de 3 Motorola E815 Front Screen Replacement: paso 12, imagen 2 de 3 Motorola E815 Front Screen Replacement: paso 12, imagen 3 de 3
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
  13. Motorola E815 Front Screen Replacement: paso 13, imagen 1 de 2 Motorola E815 Front Screen Replacement: paso 13, imagen 2 de 2
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
Conclusión
Zoie E
Miembro Desde 01/12/11
603 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-8, Forte Winter 2011 Miembro de Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,318
