Saltar al contenido principal
Motorola Droid X2 Motherboard Replacement
Qué necesitas
  1. Motorola Droid X2 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Motherboard Replacement: paso 2, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 2, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 2, imagen 3 de 3
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Motherboard Replacement: paso 4, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 4, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 4, imagen 3 de 3
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Motherboard Replacement: paso 5, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Motherboard Replacement: paso 6, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 6, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Motherboard Replacement: paso 7, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 7, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 7, imagen 3 de 3
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Motherboard Replacement: paso 8, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Motherboard Replacement: paso 9, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 9, imagen 2 de 2
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Motherboard Replacement: paso 10, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 10, imagen 2 de 2
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Motherboard Replacement: paso 11, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 11, imagen 2 de 2
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Motherboard Replacement: paso 12, imagen 1 de 2 Motorola Droid X2 Motherboard Replacement: paso 12, imagen 2 de 2
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Motherboard Replacement: paso 13, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 13, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 13, imagen 3 de 3
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Motherboard Replacement: paso 14, imagen 1 de 3 Motorola Droid X2 Motherboard Replacement: paso 14, imagen 2 de 3 Motorola Droid X2 Motherboard Replacement: paso 14, imagen 3 de 3
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Conclusión
Una persona más ha completado esta guía.
Aaron Mak
Miembro Desde 10/29/14
658 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 4-3, Miles Fall 2014 Miembro de UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 757
