Saltar al contenido principal
Motorola Droid X Rear Case Replacement
Qué necesitas
  1. Motorola Droid X Rear Case Replacement, Rear Case: paso 1, imagen 1 de 1
    • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
  2. Motorola Droid X Rear Case Replacement: paso 2, imagen 1 de 1
    • INSTRUCTION: Turn the phone over so that the back faces up.
  3. Motorola Droid X Rear Case Replacement: paso 3, imagen 1 de 1
    • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
  4. Motorola Droid X Rear Case Replacement: paso 4, imagen 1 de 1
    • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
    • INSTRUCTION 2: Slide down the battery case plate.
  5. Motorola Droid X Rear Case Replacement: paso 5, imagen 1 de 1
    • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
  6. Motorola Droid X Rear Case Replacement: paso 6, imagen 1 de 1
    • Objective: remove the battery from the battery compartment.
  7. Motorola Droid X Rear Case Replacement: paso 7, imagen 1 de 1
    • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
  8. Motorola Droid X Rear Case Replacement: paso 8, imagen 1 de 1
    • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
  9. Motorola Droid X Rear Case Replacement: paso 9, imagen 1 de 1
    • INSTRUCTION: Remove two black screws from the back of the phone.
  10. Motorola Droid X Rear Case Replacement: paso 10, imagen 1 de 1
    • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
  11. Motorola Droid X Rear Case Replacement: paso 11, imagen 1 de 1
    • INSTRUCTION: Flip the phone over to the front side.
  12. Motorola Droid X Rear Case Replacement: paso 12, imagen 1 de 1
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
  13. Motorola Droid X Rear Case Replacement: paso 13, imagen 1 de 1
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
  14. Motorola Droid X Rear Case Replacement: paso 14, imagen 1 de 1
    • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
  15. Motorola Droid X Rear Case Replacement: paso 15, imagen 1 de 1
    • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
  16. Motorola Droid X Rear Case Replacement: paso 16, imagen 1 de 1
    • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
  17. Motorola Droid X Rear Case Replacement: paso 17, imagen 1 de 1
    • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
  18. Motorola Droid X Rear Case Replacement: paso 18, imagen 1 de 1
    • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
  19. Motorola Droid X Rear Case Replacement: paso 19, imagen 1 de 1
    • Now you are ready to access the internal circuits of the phone.
Conclusión
2 personas más completaron esta guía.
Anna
Miembro Desde 10/08/12
28 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-1, Voss Fall 2012 Miembro de Ohio State, Team 1-1, Voss Fall 2012
OSU-VOSS-F12S1G1
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 862
