Partes
No se requieren partes.
Follow removal of rear housing guide. This should be your starting point.
  • Follow removal of rear housing guide. This should be your starting point.
Agregar Comentario
Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
  • Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
Agregar Comentario
  • Peel away second layer of tape and smaller circuit wiring.
  • Use caution as this wiring is extremely fragile.
Agregar Comentario
  • Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
Agregar Comentario
  • Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
Agregar Comentario
  • Pull camera up from rear housing of phone using fingers.
Agregar Comentario
  • Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
Agregar Comentario
  • Completed.
Agregar Comentario
Conclusión
Equipo
Ohio State, Team 1-1, Buehl Fall 2012 Miembro de Ohio State, Team 1-1, Buehl Fall 2012
OSU-BUEHL-F12S1G1
4 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,229
