Saltar al contenido principal
Motorola Droid Turbo Rear Case Replacement
Qué necesitas
  1. Motorola Droid Turbo Rear Case Replacement, Rear Case: paso 1, imagen 1 de 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Rear Case Replacement: paso 2, imagen 1 de 2 Motorola Droid Turbo Rear Case Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
Conclusión
Geoff Wacker
Miembro Desde 09/30/13
89,934 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,573
