Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Motorola Droid Turbo Motherboard Replacement
Qué necesitas
    1. Motorola Droid Turbo Motherboard Replacement, Rear Case: paso 1, imagen 1 de 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Pregunta a FixBot
      Agregar Comentario
    2. Motorola Droid Turbo Motherboard Replacement: paso 2, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 2, imagen 2 de 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Pregunta a FixBot
      Agregar Comentario
    1. Motorola Droid Turbo Motherboard Replacement, Midframe: paso 3, imagen 1 de 1
      • Remove the midframe bezel.
      Pregunta a FixBot
      Agregar Comentario
    2. Motorola Droid Turbo Motherboard Replacement: paso 4, imagen 1 de 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Pregunta a FixBot
      Agregar Comentario
    3. Motorola Droid Turbo Motherboard Replacement: paso 5, imagen 1 de 1
      • Remove the midframe.
      Pregunta a FixBot
      Agregar Comentario
    1. Motorola Droid Turbo Motherboard Replacement, Battery: paso 6, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement, Battery: paso 6, imagen 2 de 2
      • Use the point of a spudger to pop up the battery connector.
      Pregunta a FixBot
      Agregar Comentario
    2. Motorola Droid Turbo Motherboard Replacement: paso 7, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 7, imagen 2 de 2
      • Fold the wireless charging coil away from the battery.
      Pregunta a FixBot
      Agregar Comentario
    3. Motorola Droid Turbo Motherboard Replacement: paso 8, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 8, imagen 2 de 2
      • Use a spudger to gently pry the battery up from the rest of the device.
      • The battery is secured with some moderate adhesive, so some force may be necessary.
      Pregunta a FixBot
      Agregar Comentario
    1. Motorola Droid Turbo Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
      • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    2. Motorola Droid Turbo Motherboard Replacement: paso 10, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 10, imagen 2 de 2
      • Remove the lower antenna board.
      Pregunta a FixBot
      Agregar Comentario
    3. Motorola Droid Turbo Motherboard Replacement: paso 11, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 11, imagen 2 de 2
      • Remove the SIM card holder/volume button rocker.
      Pregunta a FixBot
      Agregar Comentario
    4. Motorola Droid Turbo Motherboard Replacement: paso 12, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 12, imagen 2 de 2
      • Carefully lift up the motherboard to expose the display connector.
      Pregunta a FixBot
      Agregar Comentario
    5. Motorola Droid Turbo Motherboard Replacement: paso 13, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 13, imagen 2 de 2
      • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
      • Pull the display ribbon cable free of the connector.
      • At this point, the motherboard has been removed from the phone. The following steps will detail removing the wireless charging coil, as well as both cameras so that they can be transferred to the replacement motherboard.
      Pregunta a FixBot
      Agregar Comentario
    6. Motorola Droid Turbo Motherboard Replacement: paso 14, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 14, imagen 2 de 2
      • Use the flat end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    7. Motorola Droid Turbo Motherboard Replacement: paso 15, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 15, imagen 2 de 2
      • Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
      Pregunta a FixBot
      Agregar Comentario
    8. Motorola Droid Turbo Motherboard Replacement: paso 16, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 16, imagen 2 de 2
      • Remove the front-facing camera.
      Pregunta a FixBot
      Agregar Comentario
    9. Motorola Droid Turbo Motherboard Replacement: paso 17, imagen 1 de 2 Motorola Droid Turbo Motherboard Replacement: paso 17, imagen 2 de 2
      • Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
      Pregunta a FixBot
      Agregar Comentario
    10. Motorola Droid Turbo Motherboard Replacement: paso 18, imagen 1 de 3 Motorola Droid Turbo Motherboard Replacement: paso 18, imagen 2 de 3 Motorola Droid Turbo Motherboard Replacement: paso 18, imagen 3 de 3
      • Remove the rear-facing camera.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Luis Arangu
Miembro Desde 01/20/16
1,151 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 15-5, Remmell Spring 2016 Miembro de USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
Miembros de 3
48 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 62
Todo El Tiempo: 8,024
