Saltar al contenido principal
Introducción
Use this guide to replace the display assembly on your Motorola Droid Turbo. If your replacement display assembly does not include a earpiece speaker, you'll need to swap your existing one over to it.
  1. Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Use a plastic opening tool to pry the rear case off of the rest of the device. Remove the rear case.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Remove the midframe bezel.
    • Remove the midframe bezel.
  4. Remove the four Torx T5 screws securing the midframe plate.
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Remove the midframe.
    • Remove the midframe.
  6. Use a Jimmy to pry under the speaker and lift to remove it. Be sure to place your tool under the entire speaker assembly, against the plastic frame, and pry there.
    • Use a Jimmy to pry under the speaker and lift to remove it.
    • Be sure to place your tool under the entire speaker assembly, against the plastic frame, and pry there.
    • These photos show an incorrect tool position—prying this high up on the speaker assembly may damage it. Place your tool underneath the speaker assembly, not on the edge as shown here.
    • The speaker is secured with some light adhesive, so some force may be required.
  7. Use the point of a spudger to pop up the battery connector. Use the point of a spudger to pop up the battery connector.
    • Use the point of a spudger to pop up the battery connector.
  8. Fold the wireless charging coil away from the battery. Fold the wireless charging coil away from the battery.
    • Fold the wireless charging coil away from the battery.
  9. Use a spudger to gently pry the battery up from the rest of the device. The battery is secured with some moderate adhesive, so some force may be necessary.
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
  10. Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
    • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
  11. Remove the lower antenna board. Remove the lower antenna board.
    • Remove the lower antenna board.
  12. Remove the SIM card holder/volume button rocker. Remove the SIM card holder/volume button rocker.
    • Remove the SIM card holder/volume button rocker.
  13. Carefully lift up the motherboard to expose the display connector. Carefully lift up the motherboard to expose the display connector.
    • Carefully lift up the motherboard to expose the display connector.
  14. Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector. Pull the display ribbon cable free of the connector.
    • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
    • Pull the display ribbon cable free of the connector.
Conclusión
15 personas más completaron esta guía.
Geoff Wacker
Miembro Desde 30/09/13
85,608 Reputación
89 Guías creadas
8 comentarios
This has a bunch of unecessary steps and is missing so,e just kinda bricked my phone thanks to this
fake name - Contestar
Yep. It repeats a bunch of steps, and seems to switch from replacing the display to replacing the motherboard. :(
Richard Klein -
has anyone ever had the buttons break on this phone? i know on my old droid maxx one little mistake when putting the board in the metal frame was enough to break the volume buttons.
Dudefoxlive - Contestar
You don’t need to remove the battery from the board…the whole thing comes up as one.
Jason Stewart - Contestar
What if your screen is glitchy after the install?
Help me J - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 16,261
