Saltar al contenido principal
Motorola Droid Rear Case Replacement
Qué necesitas
  1. Motorola Droid Rear Case Replacement, Battery: paso 1, imagen 1 de 3 Motorola Droid Rear Case Replacement, Battery: paso 1, imagen 2 de 3 Motorola Droid Rear Case Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Rear Case Replacement: paso 2, imagen 1 de 1
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Rear Case Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Rear Case Replacement: paso 4, imagen 1 de 2 Motorola Droid Rear Case Replacement: paso 4, imagen 2 de 2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Rear Case Replacement: paso 5, imagen 1 de 2 Motorola Droid Rear Case Replacement: paso 5, imagen 2 de 2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Rear Case Replacement: paso 6, imagen 1 de 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Rear Case Replacement: paso 7, imagen 1 de 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Rear Case Replacement: paso 8, imagen 1 de 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Rear Case Replacement: paso 9, imagen 1 de 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Rear Case Replacement: paso 10, imagen 1 de 2 Motorola Droid Rear Case Replacement: paso 10, imagen 2 de 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Rear Case Replacement: paso 11, imagen 1 de 2 Motorola Droid Rear Case Replacement: paso 11, imagen 2 de 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
Conclusión
6 personas más completaron esta guía.
Brett Hartt
Miembro Desde 04/12/10
128,242 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,067 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 40,740
