Saltar al contenido principal
Motorola Droid RAZR Maxx Battery Replacement
Qué necesitas
  1. Motorola Droid RAZR Maxx Battery Replacement, Removing the battery: paso 1, imagen 1 de 2 Motorola Droid RAZR Maxx Battery Replacement, Removing the battery: paso 1, imagen 2 de 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Battery Replacement: paso 2, imagen 1 de 2 Motorola Droid RAZR Maxx Battery Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • After this continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Battery Replacement: paso 3, imagen 1 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 3, imagen 2 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 3, imagen 3 de 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola Droid RAZR Maxx Battery Replacement: paso 4, imagen 1 de 1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
  5. Motorola Droid RAZR Maxx Battery Replacement: paso 5, imagen 1 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 5, imagen 2 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 5, imagen 3 de 3
    • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
    • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
    • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
  6. Motorola Droid RAZR Maxx Battery Replacement: paso 6, imagen 1 de 1
    • Using the T5 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
  7. Motorola Droid RAZR Maxx Battery Replacement: paso 7, imagen 1 de 2 Motorola Droid RAZR Maxx Battery Replacement: paso 7, imagen 2 de 2
    • Insert the plastic opening tool between the rear case and motherboard assembly.
    • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
    • Carefully pull the rear case off the motherboard assembly.
  8. Motorola Droid RAZR Maxx Battery Replacement: paso 8, imagen 1 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 8, imagen 2 de 3 Motorola Droid RAZR Maxx Battery Replacement: paso 8, imagen 3 de 3
    • Using the tip of the spudger, lift the red silicone cover off the battery terminal screws.
    • Remove the two 3.3mm T5 Torx battery terminal screws.
    • Grab the red battery removal tab and pull the battery out.
    • There might be some adhesive between the battery and motherboard assembly.
Conclusión
9 personas más completaron esta guía.
jean Florival
Miembro Desde 10/08/14
149 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 14-6, Leahy Fall 2014 Miembro de USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Miembros
10 Guías creadas
Un comentario
can we put droid razr max battery with its cover in the xt912 (simple droid razr)
saif ur rehman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 9,919
