Saltar al contenido principal
Motorola Droid RAZR M Battery Door Glass Lens Replacement
Qué necesitas
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: paso 1, imagen 1 de 1
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: paso 2, imagen 1 de 1
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: paso 3, imagen 1 de 1
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: paso 4, imagen 1 de 1
    • Done :-)
Linea de Meta
4 personas más completaron esta guía.
Alex R
Miembro Desde 09/27/13
215 Reputación
1 Guía escrita
3 comentarios
This is not a razr maxx !!!!
Fausto Lebron - Contestar
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - Contestar
This is Droid razr m . not maxx
Qais Afridi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 7,377
