Introducción
After attempting every possible repair, your phone still doesn't function correctly. This suggests that the issue is the motherboard, but with this guide, even this component can be replaced.
Qué necesitas
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
Using tweezers, remove the metal shield protecting the rear facing camera.
Remove the two 3.5mm Torx T4 screws securing the headphone jack cable/cover.
Using tweezers, disconnect the headphone jack cable/cover and remove it. The headphone jack will stay where it is.
5 personas más completaron esta guía.
