Introducción
Use this guide to replace the entire front panel assembly on your Motorola Droid RAZR HD. This includes the
Qué necesitas
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
5 personas más completaron esta guía.
