Saltar al contenido principal
Motorola Droid RAZR Back Cover Replacement
Qué necesitas
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Droid RAZR Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: paso 2, imagen 1 de 3 Motorola Droid RAZR Back Cover Replacement: paso 2, imagen 2 de 3 Motorola Droid RAZR Back Cover Replacement: paso 2, imagen 3 de 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: paso 3, imagen 1 de 3 Motorola Droid RAZR Back Cover Replacement: paso 3, imagen 2 de 3 Motorola Droid RAZR Back Cover Replacement: paso 3, imagen 3 de 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Conclusión
7 personas más completaron esta guía.
David Hodson
Miembro Desde 04/13/10
150,997 Reputación
127 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 14,261
