Introducción
Before you begin, make sure you power down your device and work in a clean area. Also, wear a static band to prevent damage to your device.
Qué necesitas
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
3 personas más completaron esta guía.
