Introducción
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
Qué necesitas
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
Flip the board over and you will see that the camera is connected by a ribbon cable.
Unlock the cable by using a plastic remover tool then pull the camera out.
Insert the new camera and re lock the ribbon cable.
2 personas más completaron esta guía.
