Saltar al contenido principal
Motorola Droid MAXX 2 Front Camera Replacement
Qué necesitas
  1. Motorola Droid MAXX 2 Front Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Front Camera Replacement: paso 2, imagen 1 de 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Front Camera Replacement: paso 3, imagen 1 de 2 Motorola Droid MAXX 2 Front Camera Replacement: paso 3, imagen 2 de 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Front Camera Replacement: paso 4, imagen 1 de 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Front Camera Replacement: paso 5, imagen 1 de 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Front Camera Replacement: paso 6, imagen 1 de 3 Motorola Droid MAXX 2 Front Camera Replacement: paso 6, imagen 2 de 3 Motorola Droid MAXX 2 Front Camera Replacement: paso 6, imagen 3 de 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Front Camera Replacement: paso 7, imagen 1 de 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Front Camera Replacement, Front Camera: paso 8, imagen 1 de 1
    • Flip the camera backwards 180 degrees.
  9. Motorola Droid MAXX 2 Front Camera Replacement: paso 9, imagen 1 de 1
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
Conclusión
Burke Seggerman
Miembro Desde 03/18/18
704 Reputación
5 Guías creadas
Equipo
Baylor, Team S3-G4, Williams Spring 2018 Miembro de Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 258
