Introducción
This guide will take you through the process of installing a new front panel on your Motorola Droid.
Qué necesitas
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Disconnect the camera button/vibrator connector by prying it straight up off its socket on the speaker board with a spudger.
21 personas más completaron esta guía.
