Introducción
A guide to replace your Droid's broken or malfunctioning camera.
Herramientas
Partes
No se especificaron partes.
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Disconnect the camera connector from its socket by prying it straight up with a spudger.
Remove the camera assembly.
2 personas más completaron esta guía.
