Saltar al contenido principal
Motorola Defy XT SD Card Replacement
Qué necesitas
  1. Motorola Defy XT SD Card Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT SD Card Replacement: paso 2, imagen 1 de 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT SD Card Replacement: paso 3, imagen 1 de 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT SD Card Replacement, SD Card: paso 4, imagen 1 de 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
Conclusión
2 personas más completaron esta guía.
Dorian Capps
Miembro Desde 04/19/13
64 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-22, Maness Spring 2013 Miembro de Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Miembros
8 Guías creadas
2 comentarios
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - Contestar
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
Gardner Neely -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,296
