Saltar al contenido principal
Motorola Defy XT Logic Board Replacement
Qué necesitas
  1. Motorola Defy XT Logic Board Replacement, Logic Board: paso 1, imagen 1 de 1
    • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Logic Board Replacement: paso 2, imagen 1 de 1
    • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
  3. Motorola Defy XT Logic Board Replacement: paso 3, imagen 1 de 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Logic Board Replacement: paso 4, imagen 1 de 1
    • Open the plastic cover with your finger to expose the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Logic Board Replacement: paso 5, imagen 1 de 1
    • Remove the six 6mm T4 screws with the T4 torque driver.
  6. Motorola Defy XT Logic Board Replacement: paso 6, imagen 1 de 1
    • Pop out the volume button with the plastic opening tool.
  7. Motorola Defy XT Logic Board Replacement: paso 7, imagen 1 de 2 Motorola Defy XT Logic Board Replacement: paso 7, imagen 2 de 2
    • Wedge the plastic opening tool in-between the plastic layer and the front cover.
    • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
  8. Motorola Defy XT Logic Board Replacement: paso 8, imagen 1 de 1
    • Carefully separate the bottom piece from the top plastic piece.
    • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
    • The screen can now be removed.
  9. Motorola Defy XT Logic Board Replacement: paso 9, imagen 1 de 1
    • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
    • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
  10. Motorola Defy XT Logic Board Replacement: paso 10, imagen 1 de 1
    • Flip the logic board and display cover over so the camera faces away from you.
    • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
    • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
Conclusión
2 personas más completaron esta guía.
No Name
Miembro Desde 04/21/13
25 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,308
