Saltar al contenido principal
Motorola Defy Rear Facing Camera Replacement
Qué necesitas
  1. Motorola Defy Rear Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Rear Facing Camera Replacement: paso 2, imagen 1 de 2 Motorola Defy Rear Facing Camera Replacement: paso 2, imagen 2 de 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Rear Facing Camera Replacement, Battery: paso 3, imagen 1 de 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Rear Facing Camera Replacement, Midframe: paso 4, imagen 1 de 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Rear Facing Camera Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: paso 6, imagen 1 de 2 Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: paso 6, imagen 2 de 2
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
Conclusión
Morgan Roark
Miembro Desde 10/08/14
325 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 14-2, Leahy Fall 2014 Miembro de USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 379
