Saltar al contenido principal
Motorola Defy LCD Replacement
Qué necesitas
  1. Motorola Defy LCD Replacement, Rear Case: paso 1, imagen 1 de 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy LCD Replacement: paso 2, imagen 1 de 2 Motorola Defy LCD Replacement: paso 2, imagen 2 de 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy LCD Replacement, Battery: paso 3, imagen 1 de 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy LCD Replacement, Midframe: paso 4, imagen 1 de 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy LCD Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy LCD Replacement, Motherboard: paso 6, imagen 1 de 2 Motorola Defy LCD Replacement, Motherboard: paso 6, imagen 2 de 2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy LCD Replacement: paso 7, imagen 1 de 3 Motorola Defy LCD Replacement: paso 7, imagen 2 de 3 Motorola Defy LCD Replacement: paso 7, imagen 3 de 3
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy LCD Replacement: paso 8, imagen 1 de 1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy LCD Replacement, Removing the LCD: paso 9, imagen 1 de 2 Motorola Defy LCD Replacement, Removing the LCD: paso 9, imagen 2 de 2
    • Stick the metal spudger in between the LCD screen and the case of the phone.
    • Remove the LCD screen and replace with a new one.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 14-2, Leahy Fall 2014 Miembro de USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,127
