Introducción
Use this guide to replace your Defy's display assembly. Replacing the display assembly will give you a new front glass panel and digitizer.
Qué necesitas
Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
Follow this backwards to reassemble the mobile.
11 personas más completaron esta guía.
