Saltar al contenido principal
Motorola DROID RAZR MAXX Camera Cover Replacement
Qué necesitas
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: paso 1, imagen 1 de 2 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: paso 1, imagen 2 de 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: paso 2, imagen 1 de 2 Motorola DROID RAZR MAXX Camera Cover Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: paso 3, imagen 1 de 3 Motorola DROID RAZR MAXX Camera Cover Replacement: paso 3, imagen 2 de 3 Motorola DROID RAZR MAXX Camera Cover Replacement: paso 3, imagen 3 de 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: paso 4, imagen 1 de 1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Conclusión
Una persona más ha completado esta guía.
Govind
Miembro Desde 10/08/14
130 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 14-6, Leahy Fall 2014 Miembro de USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 702
