Saltar al contenido principal
Motorola DROID MAXX Full Screen Replacement
Qué necesitas
  1. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: paso 1, imagen 1 de 3 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: paso 1, imagen 2 de 3 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: paso 1, imagen 3 de 3
    • Find the volume buttons located on the side of the Droid Maxx.
    • Take the plastic opening tool and insert it into the gap between the volume buttons and the case.
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear a “snap” sound.
    • Remove the buttons carefully. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
  2. Motorola DROID MAXX Full Screen  Replacement: paso 2, imagen 1 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 2, imagen 2 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 2, imagen 3 de 3
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear an audible click.
    • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
  3. Motorola DROID MAXX Full Screen  Replacement: paso 3, imagen 1 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 3, imagen 2 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 3, imagen 3 de 3
    • Using the Torx T5 Screwdriver, carefully remove all of the screws in the motherboard.
    • There are 8 black screws: 4 at the top and 4 at the bottom of the motherboard.
    • There are 2 silver screws on the side: 1 at the bottom and 1 in the middle.
    • Use either a T3 (Ultra) or T4 (MAXX) to remove the single screw securing the camera housing.
    • Using the plastic opening tool, gently lift the two tabs in the upper plastic cover that surrounds the camera to release the cover.
  4. Motorola DROID MAXX Full Screen  Replacement: paso 4, imagen 1 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 4, imagen 2 de 3 Motorola DROID MAXX Full Screen  Replacement: paso 4, imagen 3 de 3
    • Carefully disconnect the ribbon cable from the motherboard and front screen.
    • Place the ribbon cable under the orange tape during reassembly.
Conclusión
6 personas más completaron esta guía.
Jordan
Miembro Desde 03/01/17
227 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G4, Harley Spring 2017 Miembro de IUPUI, Team S2-G4, Harley Spring 2017
IUPUI-HARLEY-S17S2G4
4 Miembros
1 Guía escrita
2 comentarios
Where can I purchase the screen replacement for the droid maxx
Zachary lawson - Contestar
That 3mm screw is a ##&&%. BE VERY CAREFUL WITH IT! I haven’t figured out how to best loosen it yet; maybe small turn bursts so you don’t break the tines?
Ron Herren - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 6,499
