Introducción
If your battery is pooped out, use this guide to replace a dead battery on the Motorola Cliq. There are no small parts to worry about.
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off. Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Agregar Comentario
Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery. The pull tab may be tucked under the battery.
  • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
Agregar Comentario
Conclusión
Tony Tran
Miembro Desde 14/04/13
64 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 10-42, Amido Spring 2013 Miembro de Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 322
