Saltar al contenido principal
Motorola C290 Logic Board Replacement
Qué necesitas
  1. Motorola C290 Logic Board Replacement, Battery: paso 1, imagen 1 de 2 Motorola C290 Logic Board Replacement, Battery: paso 1, imagen 2 de 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Logic Board Replacement: paso 2, imagen 1 de 2 Motorola C290 Logic Board Replacement: paso 2, imagen 2 de 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Logic Board Replacement, Antenna: paso 3, imagen 1 de 3 Motorola C290 Logic Board Replacement, Antenna: paso 3, imagen 2 de 3 Motorola C290 Logic Board Replacement, Antenna: paso 3, imagen 3 de 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Logic Board Replacement: paso 4, imagen 1 de 2 Motorola C290 Logic Board Replacement: paso 4, imagen 2 de 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  5. Motorola C290 Logic Board Replacement, Logic Board: paso 5, imagen 1 de 3 Motorola C290 Logic Board Replacement, Logic Board: paso 5, imagen 2 de 3 Motorola C290 Logic Board Replacement, Logic Board: paso 5, imagen 3 de 3
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
  6. Motorola C290 Logic Board Replacement: paso 6, imagen 1 de 2 Motorola C290 Logic Board Replacement: paso 6, imagen 2 de 2
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
  7. Motorola C290 Logic Board Replacement: paso 7, imagen 1 de 2 Motorola C290 Logic Board Replacement: paso 7, imagen 2 de 2
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
  8. Motorola C290 Logic Board Replacement: paso 8, imagen 1 de 1
    • Use the Spudger to detach the screen wire from the logic board.
  9. Motorola C290 Logic Board Replacement: paso 9, imagen 1 de 3 Motorola C290 Logic Board Replacement: paso 9, imagen 2 de 3 Motorola C290 Logic Board Replacement: paso 9, imagen 3 de 3
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
Conclusión
Una persona más ha completado esta guía.
Paul
Miembro Desde 04/15/10
22 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-28, Regan Spring 2010 Miembro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 1,408
