Saltar al contenido principal
Motorola C261 Screen Replacement
Qué necesitas
  1. Motorola C261 Screen Replacement, Place Phone: paso 1, imagen 1 de 1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Screen Replacement, Latch and Back Cover: paso 2, imagen 1 de 2 Motorola C261 Screen Replacement, Latch and Back Cover: paso 2, imagen 2 de 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Screen Replacement, Remove Battery: paso 3, imagen 1 de 2 Motorola C261 Screen Replacement, Remove Battery: paso 3, imagen 2 de 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Screen Replacement, Screws in Rear Housing: paso 4, imagen 1 de 1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
  5. Motorola C261 Screen Replacement, Rear Housing: paso 5, imagen 1 de 2 Motorola C261 Screen Replacement, Rear Housing: paso 5, imagen 2 de 2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
  6. Motorola C261 Screen Replacement, Spacers: paso 6, imagen 1 de 2 Motorola C261 Screen Replacement, Spacers: paso 6, imagen 2 de 2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
  7. Motorola C261 Screen Replacement, Motherboard and Front Housing: paso 7, imagen 1 de 2 Motorola C261 Screen Replacement, Motherboard and Front Housing: paso 7, imagen 2 de 2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
  8. Motorola C261 Screen Replacement, Clips: paso 8, imagen 1 de 2 Motorola C261 Screen Replacement, Clips: paso 8, imagen 2 de 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  9. Motorola C261 Screen Replacement, Button Circuit Board: paso 9, imagen 1 de 2 Motorola C261 Screen Replacement, Button Circuit Board: paso 9, imagen 2 de 2
    • The circuit board for the buttons is now free to be removed and replaced.
  10. Motorola C261 Screen Replacement, Front Speaker: paso 10, imagen 1 de 2 Motorola C261 Screen Replacement, Front Speaker: paso 10, imagen 2 de 2
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
    • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
  11. Motorola C261 Screen Replacement, Removing Framework: paso 11, imagen 1 de 1
    • Gently remove the plastic and metal framework of the phone by lifting it up.
  12. Motorola C261 Screen Replacement, Removing Screen Ribbon Connection: paso 12, imagen 1 de 2 Motorola C261 Screen Replacement, Removing Screen Ribbon Connection: paso 12, imagen 2 de 2
    • Use the prying tool to remove the connection between the display screen and the the main circuit board.
    • The ribbon is not removed. It is instead connected to the circuit board by a set of circuit connectors.
Conclusión
Jason
Miembro Desde 10/23/14
305 Reputación
3 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-6, Lauer Fall 2014
MTU-LAUER-F14S1G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 223
